Extremely Slow Start-Up, Slow to Start Typing, What is Wrong?
Hello,
I am trying to fix a MacBook Pro, but have not before encountered such symptoms.
---- What I saw and tried, chronologically:
- When it came, the laptop would get stuck at the spinning wheel.
- I removed the HDD, tried to repair it through USB connection on my own Mac, Disk Utility said it was OK;
- I tried to boot on the "bad" machine and "bad" HDD again, but through USB, got stuck at the spinning wheel;
- Took it apart: no signs of water damage or past repair; replaced the HDD cable for good measure => the laptop started getting to the prompt at the 94th second;
- Trackpad works at this point, I could move the mouse around the screen, but when I clicked on "restart" or "shut down" I got nothing;
- I tried to type use name and password, but the cursor remained stuck on user name, didn't move or register anything;
- After a while (2+ minutes, can't say) the letters I had typed before now appeared in the prompt with a delay. I logged in, and the computer behaved normally;
- I restarted it, and got the same issue again;
- Tried 1*4GB RAM 1067 in 1st then 2nd slot. Did not get to the prompt or hardly.
- I put back the 2*2GB, would still get screen color change at 94 seconds, but the prompt for user/password wouldn't appear. Once, I got distracted and when I looked back, it was back to the spinning wheel after it had "changed color.
Anyone can suggest what the problem is or how to trouble shoot it?
Thanks!
Additional info: MacBookPro7,2 / 2.4GHz Core 2 Duo / 2*2GB RAM / Attached: thermal pic of the board, seems OK I believe (outside/around the red area, temp is 45 deg. C)
Bu iyi bir soru mu?
