Why isn't my Belkin Range Extender working?
after long time having issue with connectivity and speed issue i git a new belkin range extender and now it is not working . its just 1 month old help
Bu iyi bir soru mu?
Bu iyi bir soru mu?
range extender is a plug-and-play device after setup. First connect your computer with range extender with a cable then open the default gateway IP in your browser and now put your router name and password and you will get Belkin range extender extended network as you want for more contact belkin . i hope that works for you thanks
Bu yanıt yardımcı oldu mu?
i think this Can Be a Easy Fix Cause last Night i had the same issue with my belkin extender . Just Reset Your Belkin Range Extender And Setup it Again Like Its a New Device. Since its a Plug and Play Device it Will Work . Follow This Link Belkin.range
See if this Helps You Solve the Issue
from my understanding this issue could be fixed if One can Do Proper Troubleshooting. Here is How One should fix Belkin range extender-
also i think with increasing Demand for Mesh Routers will Outrun the Traditional Router & extenders in next 5-10 Years.
Happy Ifixing
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 31
Her zaman: 29,571
1 Yorum
not working my belkin range ,what should i do?
shova lama tarafından
