There are always alternatives, some better than others. Of course soldering is the best practical option. While intimidating to those that have never done it before, it is easy. Most are intimidated from trying at some point and it not working, likely at all. But they watch videos and see others doing it and can't tell what they did wrong. Secrets are in the little details. A good condition soldering iron head, clean everything. Body oils will prevent solder from sticking. Flux is not optional. And all Flux is not created equal, and each type has a purpose. You can not just make it work with what you have. If you have plumbing Flux and silver plumbing solder, you will fail or damage your device. Silver soldering is more in. Actuality brazing. One must take a bit of time, relax and understand the details. If it doesn't flow and stick you're doing something incorrectly and you need to stop and learn a bit more, and adjust something. Don't just keep trying, you'll make things worse and harder or you'll destroy your gadget. Proper solder, Flux, clean everything, easy job.
That being said, there are other options. As said, glues are going to break. There needs to either be enough flex or rigidity to survive normal function. A usb port gets pulled, pushed, levered in every angle. They break with metallic solder connections. Super glue is only super under certain circumstances. If desperate and want some sort of possible way for a quick easy fix that will not last but will get you through a day and not make a mess of things permanently, liquid electric tape mixed with graphite or some extremely fine mesh copper or silver powder could do the job. It will not last forever. Maybe not even a day. But it buys you time. Or maybe you do it every night to charge a phone. Do what ya gotta do. Note, the more graphite or powder you add, the more conductive it will be. Also the more brittle it will be. This will give a bit of flex, and no rigidity. But it will peel right off when ready for a real repair.
There are other options not readily available to most. 3d printer metallic ink could work. There are ways to make your own. Biggest issue is most require heat to sinter properly. Heat and gadgets are generally a bad combo. There are chemical depositing methods that offer weak adhesion.
All and all, soldering is actually the easiest most straight forwards, practical solution. Even without a solder iron, there are ways if careful and ingenuitive. If it just is not working for you because you can't get the solder on the iron or to transfer you likely need to clean. Something or have a Flux or heat issue. Solder flows to heat. Cold items will not take solder. One option that can make it a touch easier to begin with is to make your own solder paste. File a piece of lead free solder till you have a small pile and mix a fraction of that in Flux paste. Just enough to make it stick together and to items. Then you can apple it to where you need, all of which got cleaned and not touched by skin, and you could use a heat gun if careful about it. If there is any pressure or force on any other wire or component in the heat it will disconnect tho. Too much heat kills components and melts plastic. If you like your gadget, and want to keep it, do it right or find help or bring it to a shop. If you can't afford to, can you afford to risk your item being permanently toasted?
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
4
I might sound like an idiot after reading some of these reviews but im going to ask this question because i honestly have no idea but solder works as a good conductor correct?
My question is do you still need a conductor to get connection eg:when replacing a jack on headphones that requires soldering wires to metal jack.I would of thought wire would conduct to jack anyhow??
Greg tarafından
