Ana içeriğe geç
Model number NX785QC8G, released in 2014. RK3188 Quad core ARM Cortex A9/1.6GHz Processor, 1GB DDR RAM.
96 Soru Tümünü görüntüle
Why am I not getting sound out of my Nextbook 8?
Whenever I try to play music or a video, my Nextbook will not play any sound. When playing a game I can adjust the volume settings, but no sound will come out.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 19
Yorum Ekle
6 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The speaker could be filled with dirt which could distort or block the sound entirely.
Take the back cover off, remove the speaker, and blow on it. If that doesn't seem to clear the dirt out, try using compressed air to remove any extra debris.
If after cleaning out the debris, the speaker still doesn't produce sound, the speaker is probably faulty. It will need to be replaced.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
How do you remove the back?
tarafından
Yorum Ekle
Or u can go back to the store and they will tell u if u did not work just get a new one
Puan 0
Yorum Ekle
If you have removed the cover in the past, you may have ripped the speaker wires from the motherboard.
Be VERY careful when removing the back cover of this tablet, the speaker is screwed to the back panel, and the leads that run from the speaker to the motherboard are very thin and there is very little slack (-/+) about an inch, 1.5 inches.
My butterfingers slipped and tore the speaker wires from the motherboard. The only way to put them back on is to solder then back on with a soldering iron. The red wire goes to the positive marked spot next to the battery connector on the right.
Puan 0
1 Yorum:
How old are you and what is your name. I am not trying to hack you I just need help.
tarafından
Yorum Ekle
Why can't I get any sound when the volume is turned all the way up?
Puan 0
Yorum Ekle
I am currently having this very same problem. Last night it worked when i went to bed. This morning. No sound. At all.
Puan 0
Yorum Ekle
No sound or camera quit working same day
Puan 0
Yorum Ekle
Yanıtını ekle
Zeke sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 7,564
