The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
461 Soru Tümünü görüntüle
Can the upper case be replaced without replacing the keyboard?
Hi everyone,
I'm thinking of bringing my MacBook Pro in to a store to get the upper case replaced under warranty (there's a mark on it), and I'm wondering, to replace the upper case, will the keyboard need to be replaced as well? Thanks in advance! :)
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Yes, Apple only sells a complete assembly. as such the Apple Store or authorized Apple Service center will replace the full assembly.
I doubt Apple will replace the upper case under warranty for a scratch. Did you spill something into the keyboard and was hoping you could sneak it by Apple? Apple has moisture markers hidden inside so if you get your system wet these markers will give you away!
I'll warn you, replacing the top case assembly is quite expensive! As it also has the battery glued to it.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorumlar:
Thanks, Dan :) No, it's a cosmetic fault I discovered upon unboxing the MacBook. I talked to an Apple technician via their Live Chat and she confirmed the fault. Thanks!
tarafından
Yorum Ekle
Yanıtını ekle
Jio Namay sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 2
Her zaman: 489
