Yes, you can. A replacement clutch can be found on ebay for $150ish. For anyone doing this, just keep in mind a few things.
1. You will need to replace the stretch belt going to the pulley. Do not re-use the one currently on it, as removing it can cause damage. A new belt is only $20.
2. You will need a gear puller tool to get the idler pulley off the compressor shaft. C clip pliers are REALLY helpful for getting that clip off. If you don't have some, buy a pair. You will use them a lot anyway!
3. After installing the new idler pulley, you will need to re-shim. I believe the proper air gap is 0.012" to 0.020" but I don't remember exactly.
Overall, the repair can be done for $200 or less if you know what you are doing, and shouldn't take more than a few hours. Really not that bad. This fix did work for me, until another unrelated part of the AC electrical system failed on me a few years later permanently killing it.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
1 Yorum
did you ever get this fixed? i have the same exact problem and i am looking to find the clutch kit, and what serial number it is.
thanks
lmv369 tarafından
