Why won't my camera turn on?
When I press the power button, nothing happens.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
The simplest reason for this problem is an issue with the battery and charging system. Make sure you are using the proper USB charger and cord and they are not malfunctioning or damaged. If everything is working normally there may be an issue with your battery, which you can replace by opening the battery compartment.
Bu yanıt yardımcı oldu mu?
I have a Samsung St77 and when I charge it with the battery inside using a usb it just blinks red light and it means that it has an error, how do I fix this?
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 1,049
1 Yorum
Mine fell down and the lens never eject
S`busiso mqapheli tarafından
