won't boot after logic & IO board replacement. What next?
I have a wine damaged MBA mid 2012. We replaced logic board and IO board, but it still won't turn on. The magsafe charger light is orange, and does't turn green after the usual time to charge. I tried resetting MMC without change. There is no noise, no light with pressing the "on" button. Nothing else is obviously damaged inside.
Update
Attached is a photo of the logic board. It's a bit different than the 11" logicboard. I'm guessing that the two solder spots highlighted might be the debug "on switch", but wanted to confirm before attempting to short them.
Two other questions: keyboard connected or not; and charger connected or not?
Thanks
TS
Bu iyi bir soru mu?
6 Yorum
We will give that a try. Is it worth flushing the keyboard with isopropyl alcohol to attempt to clean it? (assuming that it boots up with this approach)
Thanks
tpschaaf tarafından
You can do this, but make sure to let it dry without other components for at lest 24-48 hours, in front of a fan if possible
Robert tarafından
The power pads for the 13 inch are located just above the keyboard terminal. http://www.insidemylaptop.com/images/Mac.... I would leave the keyboard and battery connected, but disconnect the charging cable.
Robert tarafından
it booted up but needed the charger connected as the battery was dead. (Battery checked out ok on system check, however). I reset the SMC since it was acting a bit slow, and that worked ok, even turned on from the keyboard power button. About 10 minutes later it turned itself off. I'm charging the battery now, but it sounds like the keyboard needs to be replaced. If so, I'm looking at the $30 eBay keyboards. Any other suggestions are appreciated! Thanks.
tpschaaf tarafından
The power button worked? Hmm, do all of the keys work as well? Check to make sure you have sound as well as other basic features because the problem may be something other than the keyboard in this case.
Robert tarafından
1 tane daha yorum göster
