Ana içeriğe geç
The third-generation Ram was unveiled on February 7, 2001 at the 2001 Chicago Auto Show. This was a major update including an all new frame, suspension, powertrains, interiors, and sheet metal.
81 Soru Tümünü görüntüle
Why my door speakers aren't working
I'm having trouble with the door speakers in my dodge ram truck. Will I was driving down the road the other day the negative battery terminal came off the battery. I pulled off the road, turned the truck off and put the cable back on the battery and when I turned the truck back on the door speakers won't work. I have two subs that are still working fine even when the door speakers aren't. If I open and shut the passenger side door all 4 speakers turn on and work fine. As soon as I turn off the ignition the passenger side door speaker makes a pop and when I turn it on again they won't work until I open and shut the passenger side door. Any suggestions?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
I have just replaced the front speaker on the passenger's side on my Hemi 1500 made in 2008. Maybe it may help you. It was quite easy, as I followed these steps about changing the front door speakers on Dodge Ram. The new speaker sounds great. Thanks and good luck!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
I also had some problems with the front speaker, on the passenger’s side. I have replaced it myself, in the end. It was quite easily. If you need to do it, I found this good article about changing the front speaker on Dodge Ram. Now all my speakers sound great. Thanks and good luck!
Puan 0
Yorum Ekle
Yanıtını ekle
Drake Partaka sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 8
Son 30 gün: 21
Her zaman: 4,391
