Ana içeriğe geç
The Kenmore Elite HE3 is a washing machine by Kenmore.
636 Soru Tümünü görüntüle
How can the drum be repaired?
The drum of the washer is loose and is rubbing against the front of the washer and allowing water to be released during washing. How can this be repaired.
Update
11042822201
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorumlar:
Please give us your model number.
tarafından
Model number is 11042822201
tarafından
Yorum Ekle
MacBook Pil Tamir Setleri
Başlangıç $69.99
Buy Now
Başlangıç $69.99
Buy Now
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Rear Drum with Bearing - Part # 1515039 Mfg Part # W10253864
RepairClinic Item # 1515039
http://www.repairclinic.com/RepairHelp/H...
If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing might not be sold separately, the entire rear drum might have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorumlar:
Thanks for the information and your time
tarafından
Is there any way I can get a diagram of the washer on how to disassemble and assemble it back also I need to know the part numbers for both the bearing and the drum and where I can possibly purchase the items.
tarafından
Never mind the previous request I found what I need in your earlier reply. Thanks a lot
tarafından
Yorum Ekle
Yanıtını ekle
Von sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 262
