Ana içeriğe geç
FinePix XP50, dış etkenlerin yıpratıcı etkilerine dayanacak şekilde üretilmiştir. Bu cihazın tamiri zor olabilir ve Yıldız tornavida ve alyan tornavidaların yanı sıra, ayırma aletleri gerektirir.
Why won't my camera turn on?
Why won't my camera turn on when I press and hold the power button?
Bu iyi bir soru mu?
Puan 7
2 Yorum
Mine wont turn on either, the battery is fully charged and inserted properly. I can tell this as the pre-flash light comes on but nothing else, the only way to get the pre-flash light off again is to remove the battery.
tarafından
my camera come on then tells me to turn on and of again .please help
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
The camera most likely will not turn on because the battery is dead or because it has been inserted incorrectly. Try recharging the battery and then carefully inserting the battery back into the camera. To insert the battery correctly match the orange part of the battery with the orange part of the camera.
Bu yanıt yardımcı oldu mu?
Puan 1
4 Yorum:
I double checked and insert the battery, press on, but still doesn't work.... but it does make a dot dot dot sound.... Plz help
tarafından
It tried to turn on once, then left the lens extension out. That was the last time it turned on. I have tested the batteries, they are all testing charged. I have a FinePix S2940WM #1TD82038
tarafından
I ordered a new battery for my camera, thinking that was the problem. I inserted the new battery and nothing happened. I even put it on the charger and let it sit for about 30 minutes and still nothing. Also, how do I charge the battery? I understand plugging my camera into the cord, but is there a different way?
tarafından
Thank you so much!! My battery inside my camera, was just turned the other way around. It was just newly purchased and was second hand so I thought something might've been wrong about it. I'm so glad I found this post!!
tarafından
Yorum Ekle
I noticed environment temperature affect this - a month ago it could be turn on in temperatures below 20°C, now it requires below 18. But (1) I cannot take a refrigerator with me, and (2) after taking it from the refrigerator water wapor condensates on it, especially on optics, making it unusable.
Puan 0
Yorum Ekle
Yanıtını ekle
Matt Wilborn sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 67
Her zaman: 16,411
