Phone will NOT power up
phone was working fine. went to use it 1 hour later and it was off and yes it did and does have a full charge. Will not power on at all
Bu iyi bir soru mu?
İptal Et
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazı tamir ederken daha önceki modellerde kullanılan aynı tornavida ve plastik açma araçları gereklidir. GSM/CDMA olarak, 16,32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renkli modelleri mevcuttur.
İtibar: 11
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz AtınDoes the phone respond with a vibrate (loop?) when connected to charge?
Does the phone respond with a chirp when connected to iTunes via USB? You may want to try a "Reset" or "Restore".
Reset: https://support.apple.com/en-us/HT201559
Restore: https://support.apple.com/en-us/HT201263 *Make sure data is backed-up first!
If Display will still not turn on, it is possible a connector inside the phone may be loose or the LCD backlight may not be turning on. *Look very closely at the screen with a flashlight.
**A small percentage of iPhone 5/5S's have also unfortunately experienced some "Power Management IC" failures, where it suddenly fails to charge the battery. It may "pretend" to charge or give a false reading. This is a possibility that can be looked into after ALL other simple problems have been eliminated, as this is a logic board chip failure.
Yorumlar:
Thank you very much, it was giving a false charge reading. I held down the Power button and round finger print button at the same time and it found enough power to power up the Apple logo to indicate a dead battery. I plugged my USB cable into another charger and it works, so bottom line Bad charger.
lanty5150 tarafından
I'm glad to hear of your discovery. Long live iPhone 5S (-:
recellvalue tarafından
Son 24 Saat: 1
Son 7 Gün: 4
Son 30 Gün: 15
Her zaman: 533
Sorry It will NOT power up
