Ana içeriğe geç
Huawei Ascend G510 Android smartphone. Announced 2013.
12 Soru Tümünü görüntüle
Soru Kapandı
My phone won't turn on but it charges
can you help me my phone won't turn on but it charges
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
2 Yorum:
nuk i punojn programet.te gjitha programet jan ndalur
tarafından
ju lutem riprogamone
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
May you will find any solution here:
Step 1: Troubleshoot your cable, charger, outlet & case
Use the charger and cable that came with your device. To check that the charger and cable are working, try them with another device.
Check that the cable is securely connected to the charger and to your device. Check that there's nothing in your device's port, like dust or lint.
Plug the charger into a wall outlet. To check that the outlet is working, plug in something else, like a lamp.
Check that no accessories, like cases or battery packs, cover your device's sensors or press its buttons.
Step 2: Troubleshoot your battery charge
Within 1 minute after you've plugged in your Android device with a working cable, charger, and outlet:
If you see a battery icon, your device is powered off and is charging. You can restart right away.
If you see a red light, your battery is fully discharged. If the red light is flashing, there isn't enough power to turn on. Charge your device for at least 30 minutes before restarting.
To restart your device, press and hold the power button for a few seconds. Then, on your screen, tap Restart Restart. (If you don't see "Restart," press and hold the power button for about 30 seconds, until your device restarts.)
Note: Battery icons and lights can vary by device. For your device's details, contact your device manufacturer.
Step 3: Troubleshoot your screen
If you don't see a battery icon or red light after you plug in your Android device, the issue could be with your screen. If the device can get calls:
Press the power button for about 30 seconds.
Wait about 2 minutes.
Make your device ring. You can call it from another phone or use Find My Device. Learn how.
If your device rings, learn how to troubleshoot your screen.
and One last
Step 4: Troubleshoot with advanced steps
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 815
