Water damage no display
My iPhone 5 got "damp" after sailing. No response for 7 hours. Full charge after 8 hours and Siri is active but I have no display. Suggestions?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Tom R, bad display or bad backlight filter/circuitry. Open your iPhone by using these guides. Clean the whole phone with a high grade (90%+) isopropyl alcohol and a soft brush to clean it. Here is an excellent guide on how to clean an iPhone. It was written for a 3GS but all the steps are still pertinent to your phone as well. Once you clean it properly , I'd suggest to replace the battery as well. Humidity etc. can cause to battery failure later on. While you clean pay particular attention to the small components around the display connector. Check for corrosion, visible damage etc. Replace the display if it still should not work after properly cleaning it . It is a lot cheaper and easier than doing some board level repair which would be the next step.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 110
