Ana içeriğe geç
Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
342 Soru Tümünü görüntüle
Fuzzy loading screen then white.
I was told it was a hard drive issue but am unsure if it is. The fuzzy screen with the loading makes me think gpu. If it is gpu where do I get a replacement? The first 2 pics are of normal boot. The 3rd pic is safe boot and specs. pic 4 is of the entire screen in safe boot.
Bu iyi bir soru mu?
Puan 2
3 Yorum
Can you take a snapshot of the screen so we can see what you see. Post it here by editing your question and using the ribbon menu button on the far right in the dialog box.
tarafından
thanks for the reply hope those pics help.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
At this point it could still be the LCD display or the LVDS cable or the GPU card. Its clearly not the Hard drive.
Do you have an external monitor which you can plug in to see if the problem follows? If it does then its the GPU card, if not then the internal LCD display and/or the LVDS cable is damaged.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
I do have 2 monitors. 1 hdmi and 1 dvi. I will get an adapter and try that.
tarafından
I connected my external monitor to it and it looked the same as the imac in dual display. I guess finding a gpu is my next step. I assume I have to open up the imac and find out what gpu i need, or is the specs that i pulled up in safe mode all the info I need to buy the correct gpu?
tarafından
Yorum Ekle
Yanıtını ekle
ishkapiddle sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 366
