Data cable replacement 2133 / 2266 same?
Can the hard drive data cable for the iMac intel 20" 2266 be used in the iMac 2133? Is installation on the 2133 the same as the 2266?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Not sure why the question here, did you damage the SATA cable? Or is the drive bad?
Both systems are SATA II (3.0 Gb/s) and the systems are laid out the same. Both support 3.5" drives and both use an external temperature sensor which is stuck on the external part of the drive.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 61
