Can we add a HDD in Acer Aspire R13?
can we add any hdd in acer aspire r13?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
You can not, because there is no 2.5" slot. It's a M.2, mSata or equivalent (I'm not sure of which) so you can only add a different SSD with the same connector. There could be two slots and only one SSD but I'm not sure either. For further information about which type of SSD you could use and if there is a second slot available you better should contact Acer technical support (also to know guarantee condition about SSD adding/changing).
edit : I'va checked and there are two slot in the R13 but I can not find which type they are.
edit2 : and finally i found it, it's a m.2 slot :
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 2,302
2 Yorum
How is it with RAM?
Can we upgrade it from 8 to 16 GB?
Does somebody know a teardown howto?
Alexander Kirchhof tarafından
You can only change storage, everything else is soldered on the motherboard or other little boards in the case. For the teardown it seems really simple, juste take a look on the link :).
http://laptopmedia.com/news/inside-acer-...
babathedwarf tarafından
