My computer shuts down soon after it starts up!
when i press the start button in the laptop it takes much time to open (more than 2 minutes) then it shuts down by its own i don't press any button
Bu iyi bir soru mu?
Bu iyi bir soru mu?
When you write "time to open" I assume you mean the system boots up and loads your OS, but suddenly it shuts down. Is it correct?
If so, check you system fan, because the problem seems to be caused by an overheating and the laptop shuts down to prevent damages.
Other thing you can check is the thermal paste condition, or even if the heat sink is correctly screwed to the mounting holes.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 426
1 Yorum
Mine, if run on battery is won't shutdown but when plug it shutdown any solution pls
Abiodun Bamidele tarafından
