Ana içeriğe geç
HP G72 dizüstü bilgisayar; 17,3 inç diyagonal yüksek çözünürlüklü ekrana, şık bir tasarıma ve makul teknik özelliklere sahiptir. Aynı zamanda uygun fiyatlı bir masaüstü bilgisayar alternatifi olarak da tercih edilebilir.
My daughter's computer won't start!
This is my daughters computer and awhile back the battery stopped charging. She told me that when she would start it a message would come up asking her to press enter to continue. She got in the habit of hitting enter so one time she hit enter before she was asked and the screen went black but the computer stayed on. After awhile she unplugged the power supply to stop the hard drive from running. Since then the computer has not turned on at all. Can I save her computer or has it seen it's last?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
2 Yorum:
The message that came up that she bypassed by hitting enter, was likely a message inform you that the battery needed to be replaced. Currently, you stated that the computer does not turn on at all. Does this mean no lights come on when it is plugged in or is the screen still black.
tarafından
What happens when you remove the battery(if you can) and just use AC power?
If you can't boot, her unplugging and the battery being bad might have corrupted the hard drive. You might have to reformat it to get it to boot again.
This seems like nothing serious to be honest.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
This could be due to a number of problems. First, the hard-drive might have shut down incorrectly. If the problem is indeed caused by the battery, try using a different ac adapter. The one that the laptop had been using might have a bad capacitor. The laptop might also have to be plugged in when its being used. Another problem could be with the RAM on her computer. This is unlikely, but does produce symptoms like this. To fix that, you would have to unscrew the screws on the bottom of the PC. Once you remove the panel, you should see the RAM sticks. Try switching these around. Here is a guide: HP G72 Bellek Modülü Değişimi
There are many problems that could be occurring. These are just a few that could cause a problem like this.
Good Luck!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Robert sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 553
