Spill on MacBook Pro
How do I fix my MacBook. There was a liquid inside?
Bu iyi bir soru mu?
When liquid is spilled inside a MacBook you will often find yourself replacing several parts including the Logic Board. If it was potable water (regular old drinking water) you can often get away replacing fewer parts (usually logic board.) I would forget about repairing it if you spilled just about anything else including soda, coffee or another "sugary" liquid which usually corrode all sorts of important things inside the laptop.
Bu yanıt yardımcı oldu mu?
Most likely there is corrosion build up and causing the macbook not to turn on. What liquid did you spill on it?
If you can take the computer apart and find the sight of the corrosion, the solution could be as simple as removing the corrosion with a toothbrush, and some isopropyl alcohol. The 8-Bit Guy has a good tutorial on how to fix this problem.
For mine, it only just occurred today 2018-July-17. What is the best way to pour it out? I think I got most of it, but...
What angle should it be at?
Vent side down with laptop closed?
Vent side down with laptop spread 90 deg open?
Track pad down?
Other?
It’s filtered drinking water.
I'm not too sure as I've never personally dealt with a water damaged MacBook before, but according to OSXdaily.com they recommend positioning the MacBook like so...
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 493
3 Yorum
This is like asking how long is a piece of string.
What is wrong with the laptop? What is it doing, or not doing? What does it look like inside?
Info and we can help.
zzz tarafından
Will a part from a '57 Chevy short block fix this? Does my butt look big in this? How about giving us the last four figures of your serial number and just what will and won't work on your machine.
mayer tarafından
I thought your butt looked smaller Mayer ;-}
Dan tarafından
