How do I change my fuel filter
What steps and how do I change the fuel filter in my 2010 Honda Civic?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Albert Miller, it is bundled with the fuel pump, pressure regulator, and fuel level sending unit in the gas tank. There is an access panel in the trunk in the middle of the floor right behind the rear seats
Bu yanıt yardımcı oldu mu?
Your car does not have an (external) fuel filter like older Civics. It does have an in-tank filter that is connected to the fuel pump, which is in the fuel tank.
How would i drain all the fuel out ?
On most modern vehicles, the fuel filter, fuel pump, sensors, and other ancillary hardware are all located in the gas tank. They're designed to last the life of the vehicle and as such aren't easy to service. Gasoline is pretty clean these days so there's little reason to change the filter unless you have a specific reason.
Pick problems in hilly areas. Sometimes raise in temperature by two bars
My 2006 Honda Civic hybrid keeps jumping as I'm driving what would cause this
Son 24 Saat: 14
Son 7 gün: 89
Son 30 gün: 371
Her zaman: 46,714
1 Yorum
Location of fuel filter on Honda covic
John Kulp tarafından
