Ana içeriğe geç
Tengda S5+, çoklu dokunmatik, bar tipi bir akıllı telefon ve Tengda S serisindeki en yeni modeldir.
My battery won't charge?
I've had my phone for about a year now, and for some reason the battery won't charge when I plug it into the charger?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
1 Yorum
Charging not store
tarafından Paylaş
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hello Jholmesford,
  • Accessory may not supporting to your device
As you got high capacity (3.2Ah) battery it required original charging accessory to use otherwise it will take long time to get fully charge. When you plug the original charger phone will automatically change the charging mode to rapid charging and phone will be charge around 80% withing 1 hr and 30 Mins. if you don't have original charger you may required to use 5V 2A Charger.
  • USB port
Check whether any sign of damage or corroded in micro USB port. if it is you can clean the port
  • Power source
Check in the setting whether you phone identify the power source, Connect phone to charger Path: Setting - About phone - Status- Battery (Charging should be AC) anyhow it shows as USB there is something wrong with your USB port or Power IC
Hope this answer help you to troubleshoot the fault.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
mon téléphone ne veut pas charger
Puan 0
1 Yorum:
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Jholmesford sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 31
Her zaman: 631
