Ana içeriğe geç
Repair guides and disassembly information for Apple's Macintosh personal computers.
35804 Soru Tümünü görüntüle
Problem opening a downloaded zip file in winzip 9.0
We are using ZipOutputStream for downloading a zip file. Iam having problems in opening this zip file in winzip 9.0 but the same fiel opens fine in winzip 8.0.
But when i write the same file using FileOutputStream and ZipOutputStream into the server that file opens fine in Winzip 9.0.
The error iam getting is "Start of central directory not found:zip file corrupt.
Possible cause: File transfer error"
When i try to fix the problem using the Winzip command line Add-ON
it fixes the problem by saying the file has "extra 12 bytes at beginning of the file"
What could be the reason for having this extra 12 bytes only when i do a download but not when i write it into a file.
Please help me if you have any information on this
Thanks
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
MacBook Pil Tamir Setleri
Başlangıç $69.99
Buy Now
Başlangıç $69.99
Buy Now
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
All what you need is to follow next instructions, and via Windows instrument you may do it..
- Click on the "Start" button, click on "All Programs" and then go into "Accessories."
- Right-click on the "Command Prompt" program and select "Run as administrator."
- Type "cd directory_path_to_zip" where "directory_path_to_zip" is the fully qualified path to the corrupted zip file, such as "C:\Windows\" if your ZIP file is located in the Windows directory on your computer.
- Press the "Enter" key and then type "c:\windows\system32\wzzip -yf corrupt_zip.zip" where "corrupt_zip.zip" is the name of the ZIP file you want to try and recover.
- Press the "Enter" key and Windows attempts to fix the corrupt ZIP file. If this process is successful, a new ZIP file is created in the directory alongside the corrupt zip file with the same name as the corrupt zip file, only with the suffix "FIXED" on the end.
Some links which might be helpful to you...
http://itknowledgeexchange.techtarget.co...
http://www.reddit.com/r/Winzip/comments/...
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I don't think this is the right community to assist in debugging your Java application.
The second answer on this stack overflow may be pertenent:
http://stackoverflow.com/questions/14462...
Puan 0
Yorum Ekle
Yanıtını ekle
carmelobeach sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 Gün: 19
Son 30 Gün: 124
Her zaman: 3,807
