Ana içeriğe geç
The 7 inch third generation of Nook color tablets by Barnes & Noble, not to be confused with the 9 inch Nook HD+.
30 Soru Tümünü görüntüle
Nook HD boots to 99% then powers down.
Really weird, I've tried resetting it to factory default by holding down the nook button. Display works, fully charged (doesn't seem to be a battery issue). Every time I try to power it on, it loads to 99% then powers down. Please help! Any advice greatly appreciated.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hello claytonpcguy,
Few steps to fix you phone
Step 01
  • Turn off you phone
  • Hold the power button + home/n button
  • You can see recovery mode
  • There is a option Format cache partition (Use navigation keys to select option)
  • after formating cache partition you can reboot the phone (1st option)
  • check whether it works as usual if not fallow step 02
Step 02
  • There is a option factory default mode (All data will be lost in this step)
  • Reboot the system
  • it should work as usual
Core component or partition table relate issues may not solving formatting the device. you should have to update firmware or flash the phone to boot it up
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
claytonpcguy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 455
