Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
fan & drive spin, light on - everything stops
Hey everybody,
Computer was in sleep mode and when we tried to wake it, the fan spun as if the unit was overheating. Forced shutdown (unplug).
No I've tried many times to restart. The fan & drive start to spin. The light comes on. Then the unit stops. This happens in less than 10 seconds. The screen never turns on. It never gets to the step of booting up and looking for startup.
I'm guessing it is the logic board or the power supply.
Any help? How can I find and isolate the problem?
thanks,
T
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevapvvbh
Filtre ölçütü:
Seçilen Çözüm
Hi, I am including a link to Apples troubleshooting guide for your computer. Good luck. Ralph
http://support.apple.com/kb/TS2094
Bu yanıt yardımcı oldu mu?
Puan 3
Yorumlar:
+ for the hard work
tarafından
tarafından
I've checked that out. It is a moot point:
I get no start-up sound.
I've tried the traditional methods of resetting the PRAM, etc. No avail.
This is, apparently, the annoying a1144 model where you don't have the diagnostic LEDs (at least not visible when the case is opened).
Removing the front cover and screen didn't show any obvious signs of something being "fried"
What should be my next step?
tarafından
Hi Tommyp I am including another link that may help. I also remember reading somewhere that if the USB port worked when you turned the computer on the power supply was ok--you might check that. Let me know if this helps. Ralph
http://www.appledefects.com/wiki/index.p...
tarafından
Found the link about the USB power supply check. Was for a Intel iMac- don't know if would apply in your case but I am including it for you. Ralph
My Mac will not power up?
tarafından
Yorum Ekle
Yanıtını ekle
Tommyp sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 2,070
