iPhone 6 rear camera and flash not working
Hi all!
I dropped my phone and replaced the screen. Everything was working fine after the replacement of the screen.
I tried to open the camera app and the only thing I can see is a black screen with the record button etc.
Also when I tried to switch the flashlight on, nothing happened.
The flashlight and camera are 2 different parts, but does the one not work if one is broken?
Hope someone could help me to solve this problem. Thanks in advance!
Bu iyi bir soru mu?
5 Yorum
I'm also facing same problem.. Can I know how you fix that problem.
Thank you.
Karthik br tarafından
Hope this may help but you lost that stone ( idk wt v call it ) which is present between camera and flash without that both of them will not work flash and rear camera but front cam should work fine
rithvik singh tarafından
My camera works fine but the flash/flashlight does not. Can the LED light be replaced. I've been to Apple store and they offered me a new phone for $250. Too much so that I can read a menu in a dark restaurant.
Karen Hajarian tarafından
OK after reading all these comments, I'm clearer about my problem. When taking a picture in front of me, flash does not work. When taking a picture of me, flash works. Any ideas on a solution?
I dropped my phone and the screen cracked but was still usable ....however, the flashlight didn’t work. I went into the camera settings and tried making the flash work. I fussed around a bit and when I saw the flash was working I went back to the flashlight icon and tried it. The flashlight worked.
Go figure!
Tom Sisco tarafından
