Ana içeriğe geç
Repair guides and support for gas and electric hot water tanks, boilers and household heat exchangers.
29 Soru Tümünü görüntüle
richmond water heater burner improperly burning orange flame?
once reaches temperture and shuts off blows out pilot light?
Bu iyi bir soru mu?
Puan 0
1 Yorum
How to fix orange flame coming from hot water heater
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The flame of any natural-gas appliance should be blue in color (with maybe a little yellow at the very tip of the flame). The orange flame of your water heater indicates that the gas is not combusting efficiently, and it's a sure sign that your heater needs adjustment or repair. This is also a safety concern because it usually means more soot (and possibly carbon monoxide) than normal is being produced by the burner each time it is used.
First, check if your burner is getting enough ventilation to facilitate proper combustion of the gas. Without enough air, the gas won't burn efficiently. Visually inspect your water heater to make sure any vents or flues are free of obstruction. Remove any items on or near the water heater that may be blocking air flow.
If that doesn't help, it's possible the orifices in the burner are clogged or dirty. Burners can accumulate scale, which is a by-product of combustion. Over time, this can limit gas flow. If this is the case, then the burners in your water heater may need to be cleaned. Check the service manual that came with your unit for the proper method for cleaning the burner.
Are you sure the pilot light is blown out each time the heater reaches set temperature? These devices are obviously designed to shut off once programmed temp is reached, which is a good thing. If the burner shuts off BEFORE reaching programmed temp, then this may indicate excessive heat is building up in the unit and tripping a thermal switch. Again, this may be a clue that the problem stems from obstructed air flow and insufficient ventilation.
Hope this helps!
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
Very good. Tell Kyle that you deserve a cookie ;-)
tarafından
Thanks, got it corrected.
tarafından
Yorum Ekle
Yanıtını ekle
jeffrey fox sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 39
Son 30 gün: 195
Her zaman: 31,328
