I cant open my iPhone,how to fix it?
i cant open my iphone..the only thing i can see when i open it is the apple sign and black screen,how can i fix this?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
what iphone do you have ?
i would first try to reset it - press and hold the sleep and the home button at the same time until the iphone restarts - if that won't help - connect it with the computer and start itunes, does itunes show any error ?
if the isn't recognized by itunes, put it in dfu mode and restore it
if you don't know how to put it in dfu mode - here is a HowTo video on youtube
good luck
Bu yanıt yardımcı oldu mu?
100000000 thank to you Mr.markus weiher ^^
I had the same problem.
i switched off my iphone 4s for a while. when i tried to open it, it didn't work. i connected it to my laptop and it switched on but the only thing i saw was a black light on the screen without the apple on it. then i pressed and held the sleep and home button at the same time And it worked, the apple appeared and finally i went back to business.
Thanks to Mr. Markus Weiher
thanks a lot markus its 101% working..u save my day..
thank you so much, Markus.. i had the same problem.. and, with your help, my iphone is working & no more problems... u save my day :)
ohhh my god.. ill try what you said.. ill try to hold the reset and home pages at the same time,, then after that ill wait a few seconds its work wow thank you verry muchhh
My iphone power button isnt working how can i reset without that?
My iphone 6s displays everything but will not open, its frozen. it earlier displayed that iphone is full but it will not move . i have tried top right button and home button at the same time it wont work! PLEASE HELP
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 123,322
20 Yorum
now i have a trouble in touch screen i can't inter the pass cod to open it i guess there is something wrong in the screen but in the same time i can answer the calls how that i don't know
mariamfxconsult tarafından
my iphone5 suddenly off , and then i can't open it . i try to press the sleep/wake button but still it don't work , even a light it won't show , even i charge it , it does'nt show any light . pls help me . Vincent from Philippines
Vincent Mendoza tarafından
i can't open my iphone5 ,i try to reset it but the only thing i can see is the apple sign and black screen...please help me. Deejhay from philippines
deejhay tarafından
my iphone 5s clone is cant open apps
shiva tarafından
my iphone5 suddenly off , and then i can't open it . i try to press the sleep/wake button but still it don't work , even a light it won't show , even i charge it , it does'nt show any light . please help me please
Pia michaelyn tarafından
15 tane daha yorum göster
