Ana içeriğe geç
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
544 Soru Tümünü görüntüle
Locating the fuse. Blades won't engage
Blades won't engage so thought it might be a fuse. Where are they located ?
Bu iyi bir soru mu?
Puan 5
5 Yorum
Kathy Kincade, the few fuses your mower most likely has are inline fuses. It sounds more like a mechanical issues than an electrical one. most mowers use belt drives and mechanical clutches to engage the blades. Check your belts and your pulleys to make sure those are properly placed. Also, we might find more information if you let us know what model your mower is.
tarafından
It's a GT 5000 craftsman 25 Kohler V Twin Pro. Checked belts and all are ok.
tarafından
i have been looking for the relay and cant find that location anywhere.
tarafından
same issue, fuse good, wiring fine
tarafından
Hello..My Murray 16 hp 46 in cut mower motor dies when I enggage the the blades. I replaced the fuses. Belts ob right. What could it be?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
The GT5000 is a hydrostatic drive with electric PTO. Now the fuse makes sense :-)the fuse will most likely be a green or blue fuse. The holder will be under the dash area, sometimes the fuse holder will just hang on the harness under the dash area but sometimes it is clipped onto the battery tray or the side of the dash area. in almost all cases though, it will be on the right hand side of the tractor.
I would place some weight on the seat 9i.e. sandbag etc), and nothing attached to your PTO, turn the switch on, then measure voltage to the PTO. If you have no power then check for a bad fuse, faulty wiring (especially the wires going to the clutch), faulty seat switch, etc. Also make sure that all the wires are properly connected. I attached the schematic for your mower so you can do some more testing if needed.
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
Where did I find fuse
on a cub cadet zero turn
Puan 0
Yorum Ekle
Yanıtını ekle
Kathy Kincade sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 42
Son 30 gün: 156
Her zaman: 38,895
