Ana içeriğe geç
Temmuz 2012'de Fuhu, Inc. tarafından piyasaya sürülmüştür. Model Numarası: NABI2-NV7A.
tablet speakers do not work anymore; only with headphones
my daughters tablet is not even a year old, and last week the speakers stopped working. the sound works with the headphones, but not with out! And when i tried to get customer service the hold time was over an hour, and the online ask a question wouldn't let me ask my question! Also, when registering her tablet, not all of the tabs were working so i was unable to finish that process as well! HELP!
Bu iyi bir soru mu?
Puan 21
7 Yorum
I bought two of these tablets, brand new; one in December 2014 and one in February 2015 for my two sons. In March 2015, the speakers on the first tablet stopped working. Two months later the same thing happened with the second one. This must be some sort of design flaw. I liked the tablets before this, but ran into the same problem with customer service hold times, and I also could not find the receipt for the first one, so they would not help. I ended up buying a Kurio tablet a year ago and have not had any trouble.
tarafından
I have the same issue with my Pro 12 tablet no sound coming out the speakers, works well with headphones only. How can i fix it? Is there an app to download?
tarafından
My daughters highq learning tab will only work with head phones otherwise no sound !?
tarafından
Today my sound went out and it don't work with headphones
tarafından
@Sabrina Evans how can I fix my tablet?
tarafından
2 tane daha yorum göster
Yorum Ekle
9 Cevap
Filtre ölçütü:
Seçilen Çözüm
amg112586, it is possible that your headphone jack is stuck. That way your tablet would have opened the speaker circuitry and only work with headphones. I would try to install and remove a headphone connector in rapid sequence in to the jack. Also, a few drops of high grade isopropyl alcohol might help loosen it up. Should that not work you must consider replacing the headphone jack and/or the speaker
Bu yanıt yardımcı oldu mu?
Puan 14
7 Yorum:
A drop of contact cleaner will work even better.
Note, WD-40 is not a contact cleaner ;)
tarafından
It doesn't work for the past few weeks what should I do
tarafından
reneproulx7 what have you tried? The Nabi's do have trouble with bad speakers etc.
tarafından
No good, you can see the headphone icon turning on and off so it knows that the headphones are unplugged!!!
tarafından
Thank you, doing both worked. And another thanks for the WD-40 note. That would have been my first go to! In and out worked, then to be safe, high grade isopropyl alcohol.
tarafından
Yorum Ekle
This is c a common problem with the nabis. My son's done it as well. I downloaded soundabout app and they work now. The app has a free trial to see if it works then to get it, it was $2.99. Hope this helps.
Puan 5
2 Yorum:
I downloaded the soundabout app but it still isnt working how do I turn it on to activate the speakerphone I have a nabi 2
tarafından
Sound Was ok a few minuits ago
tarafından
Yorum Ekle
Mabye replacing the earphone jack
Puan 2
2 Yorum:
You need to explain how too do it!
tarafından
Yorum Ekle
The dream tab speakers are not working show me and do it automatically
Puan 1
2 Yorum:
@reneproulx7
I had the same issue with my son's dreamtab. Both speakers was not working but the headphones did. I took the dreamtab apart and I unplugged both speakers and headphone jack than plugged them back in. I decided to test it out while the tablet was still open and everything seemed to be in good working order. I also made sure to check the tablet was up to date with the latest updates. This can be done by switching to parent mode and going into the settings. This fixed our problems, maybe could work for you also. If you need help on how to open the dreamtab, just look for a good youtube video.
tarafından
My speakers on galaxy 3 tablet isn't working either, and I can't hear a video to watch it ...please help
tarafından
Yorum Ekle
You could shut your technologies down and wait about ten minutes and see if the volume works and of it doesn't work comment on this
Puan 0
Yorum Ekle
Suck the area of the speakers.
Read this youtube comment and it actually worked.
Puan 0
Yorum Ekle
Hi !
Check the harware. I had the same issue with a Chuwi Hi8. the Speaker wire was cute close to the weld. I welded again then it work. Wires are very tiny and fragile.
Puan 0
Yorum Ekle
Try soundabout. Got my son speaker to work with it
Puan 0
Yorum Ekle
Victoria🌈 that’s trying to find her headphone
Puan 0
Yorum Ekle
Yanıtını ekle
amg112586 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 38
Her zaman: 80,054
