Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
Soru Kapandı
iPhone doesn't respond at all.
Hey iFixit members!
I do have a big problem with iPhone 5s I was using.
So the phone doesn't charge. (which is kinda weird, because the phone looks almost new, always been in a case, and never dropped or opened) I checked the lightning port on iPhone, and it was clean. As you can see.
It works only with one cable. I have tried almost 10 different cables and still it didn't work.
I work a lot with iPhones, as I'm changing screens and batteries usually, still i haven't never experienced this kind of problem.
What can cause this problem? Thanks!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
If it is not charging at all with any of the original cables and/or does not connect to iTunes on your computer and/or works ok on a new charged battery, but won't restart once battery is empty, then you probably have a failing U2 USB charging/control IC.
You should rule out charging dock failure by trying a new known good one (no need to remove the old, just disconnect it, overlay the new one over it, and plug it into the board and test).
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
How it can be broken? And thanks, ill order it =)
tarafından
Yorum Ekle
Have you tried using the different cables that does not work, both "front" and "back"?
If they work one way but not the other, it's either a missing or bent pin in the iPhone's Lightning dock, thus you'd need a replacement lightning dock, ans Rany said. So deffinately try that.
Puan 2
1 Yorum:
Thanks for your comment! Yeah, I have tried with all kinds of chargers..
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 165
