2012 toro lawn mower sat in garage 2 months will not start
checked spark plug and changed gas still wont start. does anyone know what could be the cause.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
this could be a gummed up carburetor or dirty fuel lines as well as a stuck float valve. Squirt a little bit of gas into the carburetor and then try to start it. If it does, you know that you issue is fuel related. Remove your fuel line and clean those, make sure they are not kinked, You may have to clean your carb. Let us know what model your Toro is and what engine model it has.
Bu yanıt yardımcı oldu mu?
the model number is20370 the engine is kohler xt6.75
can you tell where the carburetor is located
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 164
