Ana içeriğe geç
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2521 Soru Tümünü görüntüle
Soru Kapandı
Why my iPhone 5 can not power off when pushing power button
My iPhone 5 can not been power off when i press power button for even longer time than 5 seconds. is this software problem or hardware problem?
thanks.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
When you press the power button, can you feel it click down? or does it just feel stiff with no click?
Bu yanıt yardımcı oldu mu?
Puan 1
7 Yorum:
Thank you Techygirl, i could pressure the power button fully down and hear the click sound.
tarafından
Sounds like the power flex has gone bad, but try Sunnys directions about the assistive touch.
Settings, general, accessibility, AssistiveTouch
tarafından
I tried but it did provide a power button in assistive touch...
tarafından
Its under DEVICE and then LOCK SCREEN on the assistive touch menu
tarafından
Pressing LOCK SCREEN will put it to sleep, holding it will give you the option to power off the phone.
tarafından
2 tane daha yorum göster
Yorum Ekle
En Yararlı Yanıt
Your power flex is most likely water damaged so when you hold it down, it is not making a solid connecting. the best way to test this out is to turn on assistive touch, and hold on to the capacitive power button.
if it is able to turn off, then is it the button issue. if it is not then, try to restore the phone in DFU mode.
hope that helps, if it does please choose my answer.
good luck!
Puan 1
2 Yorum:
Thx Sunny, would be much appreciated if you tell me how to to turn on assistive touch.
tarafından
Sunny, I tried capacitive function, but there is no power button in capacitive module. or do I have to use some tricks to power button in capacitive ? many thx
tarafından
Yorum Ekle
Your power button sounds like it's going bad. Very common issue with the iPhone 5.
Apple actually launched a recall on the issue so if you can, bring it in to apple
Puan 1
1 Yorum:
thank you YoloRepair, This problem is solved and i will contact Apple to see if it can be reparied permanently. if not i can still use it by capacitive button.
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 156
