Ana içeriğe geç
The Sony Xperia Z3 is an android smartphone released in 2014 known for it’s long battery life and durability.
114 Soru Tümünü görüntüle
How to glue properly a lcd?
Hey, i am having the same issue all the time. When i glue a lcd or glass on the frame it doesnt hold enough and then it is like that:
http://shrani.si/f/3p/J6/1ylWj2pW/img572...
What should i do? What tape should i use?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Your best bet is to actually purchase the pre cut adhesive, not only is this extremely strong, as you can usually get the original stuff that's used to hold it down, it is also quite easy to fit without mistakes.
I first tried doing it with my own double sided adhesive at first, but wasn't getting it to sit as flushly as I wanted, I then started buying the pre cut adhesives for the Xperias, and my repairs went way smoother! As an added plus, although not guaranteed, it will be more water resistant than trying to use your own adhesive. :-)
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
Have you tried applying a little bit of heat around the screen? Sometimes this will help to make the tape stickier. Just add pressure and slowly work your way around the screen applying heat as you go.
Puan 1
Yorum Ekle
Yanıtını ekle
infoservis112 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 233
