will not turn on after having a power outage
my workforce will not power up after a power outage.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
it has a fuse on the main board that seems to blow easily , if it's completely dead that's probably it , a factory repair costs more than a new printer, don't use the cleaning cycle on these more than once it uses a lot of ink and then clogs the nozzles worse than before
Bu yanıt yardımcı oldu mu?
How do I find the main board & fuse
Thanks!but where can I find the fuses ?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 5,079
1 Yorum
It may be a problem with your power cord or outlet, if it is plugged into a power strip or similar secondary power source try plugging it directly into the wall.
Tyler Momberger tarafından
