Ana içeriğe geç
The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
The X button Doesn't Work.
The X button (not the guide button) on my controller does not work; however, every other button does work. Which motherboard do I need to replace to fix this problem?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
7 Yorum
Hello, Has anyone gotten any answers on this matter? As of now this is part of an issue I am having with my controller. Should I call XBox for assistance?
tarafından
same thing has happened to me aswel… i was not bothered to much i just rerouted X to the bottom back paddle.. now the kids have broken the shells so gonna re do all the parts.. I really want to know aswell if the X button is a hardware or software problem
tarafından
It also happened with my controller from the xbox one s. Got it connected to the iPad Air and played Genshin impact. Suddenly the X button stoppend working. Connected it to my xbox and it si somehow overly sensitiv. instead of moving one tile it moves two. Updating the controller firmware did not do anything. Problem is the same. I can not point out if it is a hardware or a software problem. I only know firmware update does not cure the controller.
tarafından
mine is the Model 1708 so it seems to be a general issue
tarafından
the same thing happened to me but im still trying to figure it out
tarafından
2 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Have you tried cleaning the membrane (the rubber thingy with the buttons on it) and the motherboard?
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Take a screwdriver and press the button as much as you can i did it and it worked hope this helps
Puan 0
Yorum Ekle
Yanıtını ekle
Turner747 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 21
Her zaman: 12,806
