Ana içeriğe geç
Repair guides for portable MP3 players, released first in 1997. These devices play back stored music from hard drives or flash memory.
341 Soru Tümünü görüntüle
My MP3 player won't turn on once I remove the charger.
I can listen to my Sylvania SMP2200 2GB MP3 Player when it is charging, but once it unplug it it stops and the light won't turn on. I know it has to be fully charged to play, but it was charging all night. Any tips?
Bu iyi bir soru mu?
Puan 32
8 Yorum
I have the same problem with my bõrne 2GB MP3 player
tarafından
I recently used my MP3 player like 2 minutes ago it was charging and then randomly stopped the screen is black but I know is on cause my mp3 light Botton turns on I can’t remove the back because has no way to remove the back please helppp me my MP3 player is mahai
tarafından
I found just plugging it in for a little bit and fidgeting with the power button worked.
tarafından
My Searick digital music player model: M6 had this problem. I kept pressed power button for almost 15/20 seconds and then it became semi functional. Then I turned off and ON again and voila its perfect now with battery showing 100% charge and music functional.
tarafından
Woow! yes I did that and it worked! Thank youuuuuuuuuuuuuu!!!
tarafından
3 tane daha yorum göster
Yorum Ekle
14 Cevap
Filtre ölçütü:
Seçilen Çözüm
It sounds to me like you have a bad battery connection or a dead battery. Remove the back cover from the device. Locate the battery and its connector. DO NOT TOUCH THIS!!! It may be round or boxy. Using a spudger if you have one, otherwise use a pencil eraser, push the battery connector back in. Attempt to turn on the MP3 player. If this does not work, then you may have a dead battery.
Bu yanıt yardımcı oldu mu?
Puan 7
11 Yorum:
Do you think this could happen already? I just got it yesterday.
tarafından
same thing happened to me. I haven't even used it yet.
tarafından
Poor quality control (especially if from a "generic" brand) can pass products that don't work.
tarafından
I just got mine.... is YES a generic brand?
tarafından
My timikoo mp3 player was working fine but then it started to drain battery fast even while on charge so i turned it off to let it charge but when i woke up it was on 1% so i tried to get it to charge but then it turned of and the screen went black now it wont charge and will not turn on. PLZ HELP
tarafından
6 tane daha yorum göster
Yorum Ekle
En Yararlı Yanıt
I had this problem too its not the battery it must be switched on when charging but plug in your earphones and make sure no music is playing or the battery will be drained and it will result in no charging, That fixed mine hope it helps somebody :p :D
Puan 8
9 Yorum:
Thanks! That worked for me! :D
tarafından
I don't understand the steps. Can u explain in more detail? Please....
tarafından
It did not work for me
tarafından
I just got mine today let’s see if it works for me ^-^
tarafından
Rachel I am trying the technique you suggested now, but how long do I keep it plugged up, cause the battery indicator displays the fully charged symbol but that's obviously not the case. Please reply ASAP. Thank you.
tarafından
4 tane daha yorum göster
Yorum Ekle
I have an answer that works on the MP3 players that you push a switch up to turn it on after you push it up the swith goes down, so my answer is for those MP3 players.
The answer: Hold the power switch up for about 15 seconds, that should make it turn on
Puan 3
3 Yorum:
Thank you so much!!
tarafından
it did not work
tarafından
Thanks. It worked
tarafından
Yorum Ekle
Didn’t charge with the charger, but did so with a PC data connection; also the cable was VERY PICKY as to how much i inserted it into the player. Talking 1/10th of a mm. As soon as I got the data connection, it would charge, otherwise a (fake) charging screen. Hope that helps.
Puan 2
Yorum Ekle
Either try a new charger or get the charging panel replaced.
Puan 1
1 Yorum:
what is a charging panel?
tarafından
Yorum Ekle
it sounds like its a case of dead(drained completely and cant be re-charged.) battery
Puan 0
3 Yorum:
Can I use the charger in my wall socket to charge, or do I need to charge it from a computer? Some booklets suggest that, but some mp3 players will still charge without a computer. I don't have a computer anyway.
tarafından
it dosent mader
tarafından
I think that should be the problem 😕
tarafından
Yorum Ekle
You could get a portable charger, if nothing already mentioned worked.
Puan 0
1 Yorum:
My own charge but if i on it, it will show blue led light but it not sound if i first on it. what could be the problem?
tarafından
Yorum Ekle
The batteries get old over time and will no longer hold a charge after a while. My best bet is unscrewing the inside and replacing the small battery in it. It should work fine after that.
Puan 0
1 Yorum:
I have same problem mine wont charge, cant turn on... But I cant unscrew or anything else because it is completely made of metal body. Any help?
tarafından
Yorum Ekle
hello , dont continiue
help me please .
Puan 0
Yorum Ekle
mine only turns on when its charging i dont know what to do
Puan 0
Yorum Ekle
i need help , so my mom just gave me a gogear phillips mp3 player and when its plugged up it flashes on and off with the phillips screen on it , and it wont do anything ive tried charging it for hours , what do i do?
Puan 0
Yorum Ekle
I need help this is so hard to fix the problem with this new mp player
Puan 0
1 Yorum:
When most mp3 manual says to charge by pc which is usb 5.0 volts, the wall usb 5.4 volts... I've had some brand new and it never came on sitting in pile to get to...
It's either control board or battery dead I figured when first got it used wall charger and overload the circuit wouldn't think it would be so significant but I've had problems with a few mp3 in my pile brand new...
tarafından
Yorum Ekle
I need help on my mp3 led indicator both not blinking have changed it still the same pls solution
Puan 0
Yorum Ekle
What I did was that was try buying a new charger and then take it to a repair shop and they are really cheap
Puan 0
Yorum Ekle
Yanıtını ekle
anchorsawaybyjulie78 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 106
Son 30 gün: 520
Her zaman: 56,867
