Crackling noise inside a MacBook Pro when I shake it
Hello, my MacBook Pro sounds like there's something inside when I shake it, it sounds like a piece is moving, but the rare thing is that the sound only appears when it's turned on.
If I move my computer the the left, the thing goes to the left. If I move it to the right, it goes to the right. Up and down too.
It hasn't fallen.
It's a MacBook Pro 13" Late 2011.
Edit: Now it's happening without shaking the computer, just using it. I think it might be a problem with the fan. Any thoughts?
I found this video on the Internet, I think this is what it sounds like:
Bu iyi bir soru mu?
7 Yorum
You'll need to take the bottom cover off to see whats up here. It could be the fan or a loose screw. Just make sure to shake the system gently as you don't want to over do it and make sure to capture what falls out.
Dan tarafından
I already did that. I even disconnected the Hard Drive, but I couldn't get to see anything. It might be a loose screw, but I can't see it. Any thoughts?
Luis Cruz tarafından
Carefully disconnect the fan does that stop it? Don't run it too long without the fan though.
Dan tarafından
Hmm. How long?
Watch the video I posted. That's how it sounds.
2 tane daha yorum göster
