Why is heating my laptop
how do i resolve problems with heat in my processor
Bu iyi bir soru mu?
Bu iyi bir soru mu?
You may want to replace the thermal paste. The fan and heat sink can be removed with this guide.
If your new to thermal paste installation, check out this.
Kılavuz
Zorluk:
Orta
5 - 20 minutes
Kılavuz
Zorluk:
Kolay
10 - 15 minutes
Bu yanıt yardımcı oldu mu?
hi there. with regards to your problem, may i know how old is your notebook? and in what places you're using this? for the first possibility of overheating is DUST on your fan. the longer we use our notebook the more dust it will take inside. and for the place where you are using it...if you use this in a room where dust are everywhere then you need to open your notebook to clean only your fan. then try to boot again.
second possibility is that your fan needs to be change when it rotates very slowly. hope this will help. cheers.
2. Replace thermal grease between processor and heatsink
3. Use your laptop on a flat surface
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 3,338
