Ana içeriğe geç
Changed Keyboard - Auto Recover from Sleep when opening doesn't work
I changed the keyboard in a MacBook Pro 15 inch Penyrn model, which works fine. The trackboard works fine. My problem is that when the top is opened it doesn't recover from sleep mode. I don't know what I could have done or not done to cause this. I didn't change or replace any other component.
Thanks.
wes
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
Check the picture for step 12 of the keyboard guide. The middle cable going to the left in this pic is for the sleep sensor. Is there any way this could have been unplugged or damaged during the keyboard install? The magnet is in the display assembly (as bac said), so I highly doubt that was touched.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
there should be a small magnet which activates a reed switch - that switch signals the MB to wake from sleep. did you move or lose the magnet?
I'm not sure where the magnet is on your model - I think it might actually be in the display housing? on some older model Mac laptops it is mounted in the lower case, just above the optical drive. it is easy to move if you're not aware of its function.
the other possibility is you've disconnected the reed switch itself although that would be more obvious.
Puan 1
Yorum Ekle
When you close the display is the machine going to sleep ?
Puan 0
Yorum Ekle
Yes, it goes to sleep when closed but doesn't awaken when re-opened.
I found something about re-setting the SMC. I haven't tried it. Does this sound like a good idea?
tks
wes
Puan 0
Yorum Ekle
Puan 0
Yorum Ekle
Yanıtını ekle
wes wornom sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 10
Her zaman: 2,136
