How to open the case for HUMAX RM-F01 Remote control to the iHDR-5050?
The remote control has gathered dirt which has led to keys that need quite a lot of force to be activated. I'd like to clean it up, but I simply cannot open the case. There are no screws, no clips, nothing. The battery compartment doesn't reveal anything either. It looks and feels as if it has been glued together, but that doesn't make sense.
I'd appreciate help with this.
TIA Vince
Bu iyi bir soru mu?
3 Yorum
thank you saved me the cost of a new remote, I had to use a small paint scraper and needed to use a bit of force, cleaned the rubber put it back but had to take apart again to clean the circuit with isopropyl lucky I had some it worked the second time thanks again..... :)
Jen tarafından
Thank you very much, I managed to clean out both of our remotes, following your advice. It did take a bit of brute force, but it has saved me buying a third replacement remote. Yours gratefully, Mike
Mike List tarafından
Thanks very much for the information. I too used brute; case is rough round the edges, so sandpaper next!
Charles M. tarafından
