Ana içeriğe geç
Repair information for printers made by Canon.
427 Soru Tümünü görüntüle
keeps saying paper jam but no paper anywhere inside or out.
Nothing was dropped inside and I tried the suggestion to unplug and hit the on button couple of times but no go. I have run out of black ink but don't see why that would produce paper jam error. I have cannon pixma2900 series.
Any suggestions?
Bu iyi bir soru mu?
Puan 27
20 Yorum
and always false printing paper coming out
tarafından
I wish I knew. My Canon MG2920 is doing the same exact thing, and none of the suggestions helped. I do appreciate everyone's help on this board :-)
tarafından
I have the same problem. There was a paper jam
but I cleared it. No joy. Have dis-assemled the unit
twice and THERE IS NO JAM. Software problem?
Can the software be replaced/updated?
tarafından
Having the same problem. I did have a paper jam. I got all the paper out of the jam from all three angles. When it takes the paper, it crinkles it up and says no paper. My daughter has a project do thats already late and I'm not sure what to do ..Canon Pixma(mg6821)
tarafından
paper jam. but no paper canon IR2520
tarafından
15 tane daha yorum göster
Yorum Ekle
17 Cevap
Filtre ölçütü:
Seçilen Çözüm
General advice on ALL copier/’printer jams…a WHOLE piece of paper in should equal a WHOLE piece of paper out. No printing device has a capability to “absorb” a stray scrap of paper. Typically, a small scrap of paper will come to rest at or near a sensor or a sensor arm (also called a flag). A “paper jam”, in most home printers, does not necessarily mean that verbatim. It’s also used as a “kitchen drawer” descriptor for anything short of software, print head or other circuity issues. Always do the following at jam-time: 1) If your unit gives a sequential removal/clearing tutorial, follow it. 2)….grab any piece of paper to be removed using BOTH HANDS,-pull EVENLY with both hands, steady pressure. If the paper begins to tear STOP, try to re-grip closer to the nip (where the two rollers meet) of the rollers, and try again. Yes, I know this seems like it takes far longer than simply yanking out the offending piece, But you won’t be left without a printer because of a scrap floating around inside.,.AND MOST IMPORTANTLY,,,Always attempt to remove paper in the same direction it was travelling. It will not always be possibly to do this. At those times, try to observe anything the paper is touching as you remove it-it is relatively easy to generate sufficient force to knock a sensor flag out of position.
ALL COPIERS AND PRINTERS——-sense jams this way…..X amount of time to be picked up from the tray, and arrive at it’s first check point, and from there, to it’s next check point. That process is repeated the entire distance through the paper path. If it fails to get there on time, VIOLA!….Le Jam.
CLEAN YOUR ROLLERS…Yes, you can do it!. Use alcohol (insert joke here)and a scrub sponge…not for some types of “foam” rollers nowadays. If you put alcohol on rubber rollers, they will get clean , and will feed the paper properly. Before you clean the rollers, feel them. If they are slippery-smooth, they are too dirty, or too old. If too old, they will become sticky when cleaned, and wont become “un-sticky” for a while, if at all.
Try to never run pre-printed paper thru again. Yes, many companies say it is OK…….IT IS DEFINITELTY NOT !!!! Every piece fed thru will leave some residue on the rollers, and pre-printed ink is worse than toner. Over a brief period, the residue builds up….then the jams start because the paper is slipping, and not quite getting to its next check point. Once the roller become impregnated, they are history. Cleaning will only be a very temporary fix.
I was a Canon Tech for many years,… hope this helps you all.
Canon has an excellent end-user advice forum….when in doubt…
Bu yanıt yardımcı oldu mu?
Puan 13
1 Yorum:
Thank you very helpful.
tarafından
Yorum Ekle
En Yararlı Yanıt
Have had mine for 2 months and came up with this error. I tried everything from power cycling it to reinstalling the software. Finally decided to try and roll the paper feed rollers by hand and it corrected the error. When looking inside the printer you can see these rollers, do not touch the rollers themselves but look over to the side and you’ll see the gears that roll them, roll these a couple of times slowly. My best guess is that the motor that rolls these must get stuck at a certain spot in its cycle and causes the software to react as a paper jam when really the motor just needs be rolled out of that position.
Puan 37
22 Yorum:
I am practically crying right now because your simple advice was so helpful! I have a Canon MG3600 that had a paper jam last weekend. I *now* know how careful to be when clearing printer paper jams, but your simple fix saved me from having to purchase another new printer! THANK YOU THANK YOU THANK YOU
tarafından
Thank you very much. Your advice works for me. Super thank you.
tarafından
Works on Canon G1010 with false paper jam issues. Manually rolled a few rotations the gears on the right side. Thanks!
tarafından
Thank you very much this works on Canon Mg4200 Have been arguing with my husband for weeks as he wanted to buy a new printer as printer was stuck on paper jam and nothing could remove this display Now printer finally works although think it must need realignment as the printing is smudged and patchy but at least we can do something with it now
tarafından
It worked instantly! It is still printing fine now. That is nuts! Thank you, thank you!
tarafından
17 tane daha yorum göster
Yorum Ekle
Hidden deep within the manual is the 'bottom plate cleaning' procedure. This takes a piece of (new) paper with a crease, and sweeps out the paper path. It is meant to remove extra ink from the bottom plate, but may also remove paper blocking a sensor that would be detected as a jam.
See the manual, OR (copy and paste):
Cleaning the Inside of the Machine (Bottom Plate Cleaning)
Remove stains from the inside of the machine. If the inside of the machine becomes dirty, printed paper may get dirty, so we recommend performing cleaning regularly.
You need to prepare: a sheet of A4 or Letter-sized plain paper*
  • Be sure to use a new piece of paper.
Make sure that the power is turned on and remove any paper from the rear tray.
Prepare paper.
Fold a single sheet of A4 or Letter-sized plain paper in half widthwise, then unfold the paper.
Load only this sheet of paper in the rear tray with the open side facing you.
Pull out the paper output tray and the output tray extension.
Hold down the Stop button until the Alarm lamp flashes eight times, then release it immediately.
The paper cleans the inside of the machine as it feeds through the machine.
Check the folded parts of the ejected paper. If they are smudged with ink, perform Bottom Plate Cleaning again.
Note
When performing Bottom Plate Cleaning again, be sure to use a new piece of paper.
Puan 7
11 Yorum:
Nope didn't take paper in after holding for 8 .... Returned error paper jam. It started to go but it seems that there is this bar that comes passed the rollers is kicking the paper out. This bar is also making much racket.
tarafından
That's not good. It's likely that it's a guide rail just beyond the paper feed rollers that has broken or otherwise dropped out of position. If you can't get it back in place...call the service hotline. Canon can be very helpful; they replaced a printer for me that had a failed power supply, and didn't even want the original printer. You may have a different result, of course. Good luck!
tarafından
I'll try that ... Ty so much David for your help
tarafından
My pleasure. It's not hard to do...although it has been a long time since I have done one ;)
tarafından
i tried ur suggestion but i coulndt even get it to blink 8x..
tarafından
6 tane daha yorum göster
Yorum Ekle
I've just found on my Canon TS9155 (very similar setup to many of the modern Canon printers) that no paper jam existed, in spite of spending hours messing about with it cleaning and clearing the paper jam it stated that I had and finding nothing. I read on one of these help sites that my paper jam code was actually a workaround for Canon faults and could lead me even to an ink feed problem. So, I removed all of the six ink tanks, lightly brushed out the ink feed area, returned the tanks and switched on. There were lots of clicks and clacks (more than heard for a while) and then it fed a sheet of blank paper through and switched itself in its operational mode. Job done…but what a palaver..! Next time I'll do the same...FIRST..!
Puan 2
Yorum Ekle
I have a Canon TS8020 Printer that showed the Error Code 1300 paper jam with no paper in it. After wiggling everything inside that I could reach, I remover the CD printing tray and the issue went away. It had nothing to do with paper.
Hope this helps.
Trex
Puan 1
2 Yorum:
Have a TS9060, followed your advice, now perfect thank you
tarafından
Thank you for posting! I followed your advice for a TS8020. Removing the CD tray was the fix!
tarafından
Yorum Ekle
I had a similar problem twice, both times my wife had put a hair tie on top of the printer and it got knocked into the paper tray and fed into the bottom of the printer. I found it the first time after I was about to throw the thing away and it fell out when I turned it upside down . The second time I looked for it took the top off to get the thing out, but after reconnecting and assembling the printer gives a printer error with power light and alarm light alternating with 5 flashes of power light after hitting the power button when you go to turn it off. Looks like it is headed to the trash after all.
Puan 0
1 Yorum:
Your wife and I have something in common. Hair ties for days in my printer. Glad I'm not the only one! Now to see if I can fix it....
tarafından
Yorum Ekle
We tried everything...then I noticed dirt on my glass, so there was also some dirt on bottom where you insert paper, we tipped printer over twice tried to shake all the dirt out and put the folded paper and did what the instructions said to do and guess what??? It started working and I had just told my husband time to use the hammer or get a new one...This are really dirt sensitive... Hope it works for you, it worked for us...
Puan 0
1 Yorum:
i shaked the crap out of the g3200 upside down. it worked.
tarafından
Yorum Ekle
Just found an answer to this if anyone else is interested. Just try updating the printer driver on your computer. Then disable/enable it afterwards. Worked for me. I have a Cannon Pixma IP-2770 series.
Puan 0
2 Yorum:
Canon imageclass mf244dw paper jam error,
When i photocopy one blank paper came out to the machine and paper jam message show on screen when i check there is no paper inside the machine what i do plz give me solution...
tarafından
THANK YOU! Deleted the printer driver from my computer and reinstalled it. This worked like a charm, my printer is working again. Wish I hadn't followed a bunch of other suggestions first, oh well...
tarafından
Yorum Ekle
Sometimes there is paper stuck at printer or printer saying the paper is jam and many more issues like that.
To fix all these issues with printer follow this guide and see if this works for you.
·         First, unplug the printer from power and wait for 1 min then restart the printer.
·         Please don’t pull the paper out from a jam in the opposite direction this will create more issues.
·         Just go check to make sure there is no loose paper stuck in the loading tray.
·         You can also take out the paper roller and clean paper roller using a cotton cloth.
·         Try moving the print head to the left and restart the printer and see if this work.
·         Restart the computer or the device that you are trying to print with and restart the printer and see if this works.
Puan 0
Yorum Ekle
My Pixma iP100 developed this problem less than a year after I bought it. Although I tried a boatload of suggestions nothing worked. I finally found a simple solution. If I have one sheet of paper loaded I have a problem. If I have several sheets of paper loaded it prints fine. YMMV.
Puan 0
Yorum Ekle
I read that it can help by cleaning the print roller with a screen cleaning product, rubber alcohol or similar
Puan 0
Yorum Ekle
so i had this problem too and after trying multiple offered solutions managed to fix it like this
1) unplug and turn the printer off
2) open the front of the printer
3) gently move the print head to the right to expose some gears on the left side
4) manually turn these gears back and forth a few times (be careful not to damage the clear plastic disc next to the larger gear)
5) turn it back on and it should work
Puan 0
Yorum Ekle
False paper Error. Take the disc tray out and printer will start working again ? .
I did Everything just what it told me to.But there was no jammed paper . I kept Getting the Error .Until I removed the Disc Trey.I hope this Helps you.
Puan 0
Yorum Ekle
I have a canon MP280, i literally tried everyone's suggestions. Nothing worked, until i tried the suggestion that said "Turn it upside down and give it a good shake!! No $@$* it printed straight away!!
Puan 0
1 Yorum:
I have a Canon Pixma G2260 mega tank printer. I have a paper jam error 1300, that will not go away. I have tried everything recommended on you tube and on the Canon support page. Nothing helps. Can't even get access to the maintenance option on the printer. Does anyone have a suggestion?
tarafından
Yorum Ekle
So grateful for these answers!
Ours had a tiny piece of dried glue that had somehow worked it's way inside - we spent forever trying to manually roll, shake the machine, resetting it etc etc and eventually tried the advice of Jim Lyons who posted back in Dec 2020;
"I had a "paper jam"... I turned out to be a tiny scrap of cellophane or such inside the roller/printer mechanism. I used a combination of the User Manual instructions along with the "roller turning" instructions. Turned off and unplugged as instructed.. I used a stiff piece of photograph print paper to force into the wheels and back out again, from left to right at the entry and exit of the feeds... Turned unit back on and it spit out the cellophane tape along with a sheet of paper. YAYYYYY!!!!!
Dec 20, 2020 by jim_lyons"
We used a thick piece of card which forced the obstruction out! Machine worked straight after as though there was never an issue.
Thanks Jim :)
Puan 0
Yorum Ekle
My Pixma MG3650s was indicating a paper jam when there was none. I tried all the various on/off and shaking techniques to no avail. Then I stumbled on a "cardboard" suggestion. I opened the back of the printer and inserted the cardboard base of a notepad along the top paper tunnel until it appeared at the front of the machine. Then I retracted it. The error was eliminated and the machine was back in business.
Puan 0
Yorum Ekle
I had the same problem, my Canon TS3300 was having this problem. The paper would come 1/3 of the way in then stop and the error would appear. It was solved by getting a thin cardboard the same size as the copy paper, and pushing it slowly through the top and then pulling it out slowly from the bottom once a small portion of it reached the other side. It didn't get rid of the error on the first try, but then it ended up working properly after a couple of more attempts. SOLUTION
Canon TS3300 printer jammed but no paper is stuck inside
Puan 0
Yorum Ekle
Yanıtını ekle
Debby Mullen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 52
Son 7 gün: 308
Son 30 gün: 1,222
Her zaman: 240,403
