Where is the Camshaft sensor located
I have a hyundai sonata i cannot the camshaft sensor its a 2.4 motor
Bu iyi bir soru mu?
Bu iyi bir soru mu?
elynbert, the camshaft position sensor monitors the position of the camshaft. It is mounted at the right hand side (looking from the front of the engine)of the cylinder head. You should make out the plug with the wire and see that the sensor is being mounted with 1 10mm bolt.
To Remove Camshaft Position Sensor
1. Disconnect negative battery cable.
2. Disconnect wire connector from sensor.
3. Remove sensor mounting bolts.
4. Remove the sensor from the rear of cylinder head.
To Fit Camshaft Position Sensor
1. Install camshaft position sensor in rear of cylinder head.
2. Install and tighten sensor mounting bolts.
3.Connect wire connector to sensor.
4. Connect negative battery cable.
Here is what it looks like
Bu yanıt yardımcı oldu mu?
My question is what's the easiest way to get at the bolt without dismantling several other parts or is that the only way....09' 2.4 sonata
I find the camshaft sensor on the right side. Where is the other camshaft sensor location.
Intake cmp is on the front of the engine just below the valve cover almost even with the right side of the manifold. The exhaust cmp sensor is in the same location on the backside of the head.
I have a 2009 hyundai sonata 2.4 motor does it have 2 camshaft sensor. Where are they at on the motor.
Where are the camshaft sensor on a 2009 Hyundai sonata 2.4 motor
I find the camshaft sensor on the right side. Where is the other camshaft sensor.
Son 24 Saat: 6
Son 7 gün: 40
Son 30 gün: 135
Her zaman: 36,328
4 Yorum
What year is your Sonata?
oldturkey03 tarafından
2014 Hyundai Sonata 2.4
Karl schmidt tarafından
@oldturkey03 2009
marybostian4 tarafından
@oldturkey03 2009 2.4
