Ana içeriğe geç
1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
146 Soru Tümünü görüntüle
Why do I have a circle in the middle of my screen
So when I have a white background you can see a circle in the middle of my screen. When its in color or picture its faded, it right in the middle of screen about 2 inches across. Whats going on? Can anyone help?
Bu iyi bir soru mu?
Puan 7
5 Yorum
Can you post a picture? You have to edit your original question and add it there.
tarafından
Also can you give us the last four digits of your serial number so we can correctly identify which model you have. Apple has made quite a few different versions of this system.
tarafından
ddr1 are the last four
tarafından
sorry for the poor quality pic but it only shows on a photo on a white screen and on an angle
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hey Ross hows the 429? I answered a question on wheel hope a while back remember?
So it looks like you piled something heavy on top of your very thin, very flimsy MacBook air. This has left an imprint on your diffuser.
To answer your question it shouldn't get any worse as long as you don't pile more stuff on top.
I've heard killing the light does help but not by much. As for a cheap fix you can buy an old mac air for parts if you can find one otherwise its not a cheap fix. I would learn to live with it as it is an old air. Dan says late 2010 so 5 years old.
Once again cool car. Any chance of posting a pic on this page?
Bu yanıt yardımcı oldu mu?
Puan 5
1 Yorum:
i fixed mine ross. try applying pressure on the back .
tarafından
Yorum Ekle
What I suspect happened here is you had laid something heavy on top of your air so the logo disk in the lid embossed the defuser sheets. So what you see is the light from the backlight (really on the upper & lower edge) being distorted by the damage.
Sadly, this is not an easy repair. Most people have found they end up making it worse! I would live with it, or think about finding a used display assembly to replace yours.
Update (09/20/2015)
Yes, this is the light source for the screen (Back Light).
No it won't get worse as ling as you don't put something heavy on the lid again. Frankly, you were lucky here! More often the screen gets damaged (black or color bars).
As for altering the brightness it may help to make it less noticeable. But that will only go so far.
Puan 3
2 Yorum:
So this is from the light on the back of the screen ?
if I make it so the light doesnt work will that help?
tarafından
Will this get any worse?
tarafından
Yorum Ekle
I did have this issue a couple of minutes ago after leaving my thin asus laptop shut with something over it for a couple days while I was out. Miraculously, I was able to fix this by applying pressure using my thumb against the other side of the screen on what I thought was the center of the ring before that I applied some pressure to the actual screen in the center of the bubble too if it doesn't work the first time. Maybe my case wasn't so severe if it doesn't work for you but the ring was brighter than the rest of the screen and at least an inch wide. Best of Luck!
(This is a pic of someone else doing what I did but I did it on the center of the ring and tried both sides!)
https://www.google.com/search?q=applying...:
Nice car btw.
Puan 3
4 Yorum:
Love this and it did work for me thank you so much! The same problem was on my screen and I've only had my laptop for 3 days. I was in such a panic thank you so much for your tip!
tarafından
Still works n 2019 Thanks That circle was annoying
tarafından
How long did you continue this process for until you managed to fix the problem? Because I'm now attempting to do the same thing as you've recommended but the ring of light still hasn't subsided, although I haven't been doing it regularly.
tarafından
I just did this, and it worked...kinda. I have a 2012 MBA and did just this and it made the halo ring less apparent. THANKS!
tarafından
Yorum Ekle
Ross, looks like some pressure mark on the the LCD. You could try and totally disassemble the LCD screen and check if it is the diffuser that has the pressure mark on it. Or, you can replace the LCD, lastly you could try and learn to live with it.
Puan 2
2 Yorum:
You caught me taking my dogs out ;-}
tarafından
Sorry Bud, just brought mine back in:-))
tarafından
Yorum Ekle
Yanıtını ekle
Ross sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 19
Son 30 gün: 56
Her zaman: 37,397
