Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazı tamir ederken daha önceki modellerde kullanılan aynı tornavida ve plastik açma araçları gereklidir. GSM/CDMA olarak, 16,32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renkli modelleri mevcuttur.
3883 Soru Tümünü görüntüle
iPhone 5s drains quickly even without using it
Why is my iphone 5s drains quickly even after replacement? Can anyone help me for this? It doesnt last overnight even without using it. I turn off the 3g and close all the apps. But it doesnt work for me.
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
MacBook Pil Tamir Setleri
Başlangıç $69.99
Buy Now
Başlangıç $69.99
Buy Now
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
I take it you replaced the battery? Did you get it from iFixit or somewhere else? There are a lot of poor quality batteries around but it's worth paying the extra for an iFixit one.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
If replacing the battery from a reputed seller like iFixit doesn't fix this, you could have a board issue.
Most common board issue is the U2 / USB IC being defective. This makes the phone burn through the battery very quickly, and other symptoms such as the iPhone is not detected by iTunes and/or when the battery is completely drained, it will not recharge back although the symbol on the screen will say "charging."
Other causes: poor reception causing high power consumption; OR during previous repair(s) some parts where omitted, causing the phone to have poor reception and again drain more power; OR short in some parts of the board, using up the power (must be overheating); etc.
Puan 1
Yorum Ekle
Iphone 5s.Have the same issue after battery replacement, find a temporary solution.
when Disconnected Home button flex cable from logic board, battery drain stopped.
Tried many different home buttons but when connected battery draining started again.
Couldn't find different solution.
Any idea what the problem is?
Puan 0
Yorum Ekle
Yanıtını ekle
raven gutierrez sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Her zaman: 132
