Ana içeriğe geç
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
The volume is at max and can't be decreased
seems like the volume up button always gives contact to put the sound at max. Sliding the volume down in dsi sound studio helps, but as soon as you release the slider the volume gets to max again.
Bu iyi bir soru mu?
Puan 3
3 Yorum
I noticed you never got an answer to this. Are you still having this problem?
tarafından
Did either of you get an answer to your problem or get it fixed? My sons systemis doing the same thing. Thanks.
tarafından
Did I miss understand? I thought over on Meta it was decided to vote these into comments, not Questions. The problem has never had a accepted solution in almost 9mos. Do we want to have another Question the samet?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Your "up" volume button is stuck down; check to see if any crumbs or dirt have gotten in there. You might need to replace the SD card slot and volume control assembly.
This part includes the SD card receptor, right and left shoulder button contacts, volume control buttons, and the screen adjustment controls. Görseli
Ürün
Nintendo DSi SD Ribbon Cable
$24.99
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
My thought would be that the slider button is off track and no longer adjusting the slide switch on the motherboard. You could take it apart to confirm this.
Puan 0
Yorum Ekle
Yanıtını ekle
Joost Appelmans sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 14
Son 30 gün: 32
Her zaman: 5,927
