Show code F16 and go off
Hi.my home theatre Panasonic,when I put on its show F16,and then go off
Bu iyi bir soru mu?
Bu iyi bir soru mu?
If your getting an f16 error it is a problem with your speaker connections . Are you sure its not a f61 this is a fan issue and will shut the home theatre off but the f16 wont . You just wont have sound
Bu yanıt yardımcı oldu mu?
Yes is F16,I don't get sound,so what can I do to fix this problem
I have this problem too on a SA-AK44 Panasonic
F16
Can I do something home or is necesary to consult a service?
Thank you!
it shows f61, whats that means
Could someone please explain what error f16 on panasonic stereo model sa-vkx65 mean and hiw to fix it. My system automatically just switches off while playing and displays F16 error code. Thank you in advance
its the fan that needs to be oiled just drop of wd40 then should fix it im just going throigh same thing
Hi @ glenturret,
Is it possible that the model number is not SA-8TT350 but is actually SA-BTT350?
Also is it possible that the error code is f76 and not f16?
If it is a SA-BTT350 and the error code is f76 then here is a link to the troubleshooting section of the service manual for a Panasonic SA-BTT350P Home theatre system describing what the causes may be.
Hopefully it is close enough to your model (if yours is a SA-BTT350) to be of some help.
F61 is a fan error. The machine switches off if the fan stops. Basically you just need to oil the fan bearing. WD40 is as good as anything. To get at it just peel back the circular sticker and you'll see it. One squirt and you're sorted. In the case of the SA-HT990 you don't even need to open the unit up, just unscrew the fan housing and pull it apart. There's usually two fans. So check them both.
I've had this f61 code for over a year now and had no luck with panasonic getting a solution in fact never even got an answer, I was at the point that I was going to buy another disc player but decided to try again to fix this, thank god I came across this solution online, a simple squirt with wd40 and hey presto problem solved. Fantastic. Happy again. Thanks very much to who ever posted the answer.
Hi @Roy Saviour
According to the service manual for the player an F61 error code (see p.25) means a Power circuit system failure and/or direct current flown to speaker terminal.
Go to p.19 to view the Power supply test points.
For a possible direct current flown to speaker terminal problem, check if there is a DC voltage on the player’s speaker terminals. Normally DC is not passed through to the speakers, as this would damage them. Only the AC audio signal is sent. The DC is usually blocked by a decoupling capacitor (see p.78 for the block schematic - unfortunately it isn’t very detailed.
Hopefully this is of some help.
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 88
Her zaman: 10,558
13 Yorum
Is model SA-HT70 Panasonic
george mwambipile tarafından
When I turn on the machine it says hello than go to F16 and turns off please help me to fix it ty
anne56 tarafından
we having the same problem turn on then it states please wait then flash up f16 and turn off ?
glenturret tarafından
we having the same problem turn on then it states please wait then flash up f16 and turn off ? with Panasonic SA8TT 350
nospam tarafından
8 tane daha yorum göster
