Model 5234us. 1.66GHz Intel Centrino Duo
10 Soru Tümünü görüntüle
Why Access denied repairing EDB with ESEUTIL?
Hi
I'm trying to put a restored EDB in to a clean shutdown state (its currently saying its in a dirty shutdown state). However when I run the command I get this back;
Operation terminated with error -1032 (JET_errFileAccessDenied, Cannot access file, the file is locked or in use) after 30.93 seconds.
If I use handle.exe to show the handles for objects in use then that recovered EDB doesn’t appear in the list. The main EDB does but this recovered one (that will be part of a recovery group) doesn't.
There's no AV installed (I removed it to see whether this was causing the issue though it did have an EDB exclusion).
Any ideas what may be the cause?
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorumlar:
EDB to PST Converter Tool is an effective & reliable tool provides impeccable recovery. This tool recover & repair all damaged .edb files and then transfer them into usable format that is PST. It supports all versions of Windows and restore PST files in your location. It restores all files in original formats such as HTML, Text, RTF, etc. It is preview of all damaged or corrupted EDB files before restoration. Free availability of demo edition with the help of you can easily understand the complete procesdure of recovery.For more info, visit here- https://softcart.wordpress.com/edb-to-ps... or http://www.mozesoft.com/edb-to-pst-conve...
tarafından
Marvelous Enstella EDB to PST Converter Software which easily available on online and helps to recover all different types of corruption issues from Exchange Server and gives Outlook PST and multiple formats to convert EDB Mailboxes Data with all zip attachment / properties/ journal / calendar / appointment etc. It permit that first time you can use demo version to export EDB Emails per folder into each formats without any cost.
Read More:- http://convertedbtopstfreeware.blogspot....
tarafından
It is log file related issue and I was also facing similar kind of 'Operation terminated with error -1032' error. I successfully fixed this issue with the help of this application: http://www.recover-computerdata.com/exch...
It's really very simple to use and helped me to resolve this error quickly with upto 100 % data back to their original state.
tarafından
Yorum Ekle
Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I think it is the log file that is locked. You might try a few things- cheating by moving the log files to another location and only leaving the essential log files or checking the properties on the log files. Or you can try to restore the file from backup. And if you haven't it you can try to use third-party tools like EDB Repair Kit for example. Or try A reboot server. May be it help. Always make a copy of your edb files before running any maintenance on them. http://www.edb.repair/
Look also this authoritative source.
http://www.fixya.com/support/t25426221-r...
Bu yanıt yardımcı oldu mu?
Puan 1
Yorumlar:
I am very glad that you helped me
tarafından
Yorum Ekle
If you are getting this error you can Live chat with Dux Data Recovery they will solve your problem. they will give solution within few time. and recover you lost data.
i also got this error they solved my problem and recover my data. you should also try dux edb to pst converter software.
[image]
Read more :- https://www.duxdatarecovery.com/edb-to-p...
Puan 0
Yorum Ekle
Yanıtını ekle
ClementMoody sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 Gün: 74
Son 30 Gün: 147
Her zaman: 3,066
