Unable to initialize new 1TB drive
Just installed a 1TB Drive but neglected to initialize before installation. Have been getting the flashing folder with ? mark.
However, I have an external USB flash drive 8GB with El Capitan installer mounted as external drive. That (magically) has allowed me to get to Disk Utility and see what is happening.
Disk Utility tells me the drive ST1000LM014-1EJ164 Media is Uninitialized. Other details are: Location-Internal, Capacity-1TB, Connection-SATA, Child Count-0, Partition Map-Not Supported, Type-Disk, SMART Staus-Verified, Device-Disk0.
Running First Aid is Successful (whatever that means..).
I've tried to reformat using the Erase function (choosing Format: OS X Extended (Journaled) and Scheme: GUID Partition Map) without success. The message I receive is "Erase process has failed. Press Done to continue." The details tell me the following: Unmounting disk. Wiping volume data to prevent future accidental probing failed. Operation failed ....
Any advice on what to try? My only thought is to uninstall the drive, initialize it as an external disk on another machine, and re-install. Before I do that, I'd welcome your advice.
Bu iyi bir soru mu?
8 Yorum
Just to be clear, I am only looking for a new installation of MacOSX not to transfer the contents of an existing drive.
lkaravis tarafından
How does Disk utility report that the drive is currently formatted? New or used drive?
mayer tarafından
Don't have the computer in front of me but, from memory, there is no sign of the drive being formatted at all.
lkaravis tarafından
What type of drive are you putting in a HD/SSHD or SSD? Can you tell us the exact make & model. If you are putting in a SSD you may need to update the SDD's firmware. You may also need to check the systems firmware for either case.
Dan tarafından
Hi Dan, Here's the information you requested:
[bağlı ürün eksik veya kapalı: IF107-122-2]
"Hybrid technology from Seagate combines SSD and traditional hard drive technology to provide SSD speeds from an affordable high capacity hard drive. Adaptive Memory technology keeps the files and file types you access the most ready and available for instant transfer from SSD."
I gather from the product description that this is a hybrid HD/SSHD. Any advice would be respectfully appreciated.
lkaravis tarafından
3 tane daha yorum göster
