Ana içeriğe geç
Product was released in 2009 by Presto. It can be found with Model number 04820.
2 Soru Tümünü görüntüle
Why did my hot air popper stop working mid-use?
The hot air popper was working fine and then it suddenly shut off. Why did it do this and what should I do?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The engineers at presto had a delicate balancing act. Too hot and it could start a fire. chances are you were trying to make more than a half of cup of popcorn and live at an altitude greater than 2000’. In addition to the thermal fuse a thermal switch was installed to prevent overheating. All testing for Presto was completed in EuClaire Wisconsin (low Altitude). My 10 yr old daughter tested ours out at many different altitudes and found that the fan they installed only works as designed in denser air (low altitude). If you live in Denver Colorado or Park City Utah a half cup is all you’ll ever get out of it before extensive cooling is required.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
Thank you! I was about to trash it, but this solves the mystery. Works fine with no popcorn. Was shutting off after a few seconds when overloaded and living at high altitude!
tarafından
Yorum Ekle
If the popper is plugged into the appropriate outlet, and the power cord has been thoroughly checked then the motor could be bad. To fix this issue change the motor.
Puan 0
3 Yorum:
The poplite does have a thermostat on it as a safety function. If you pop too much too often, the unit will get too hot and will stop.
tarafından
What if it doesn’t heat up once plugged in ? Junk it ?
tarafından
Check your breaker box.
tarafından
Yorum Ekle
Yanıtını ekle
Haley Stone sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 24
Son 30 gün: 133
Her zaman: 7,756
